I just spend $160 (100 + ship'g)at LIC to have the upper and lower balljoints riveted. The job was done very poorly. The rivets were barely rounded, with the shank still showing. Send the to Paragon to be finished riveted for $100, got them back, job was not much better, but in the process, the they damaged the lower balljoints.The sleeve, which holds the boot on was damaged, popped off, and can't be re-attached and a plastic ring was missing.
My problem is now, that I have to replace both lower balljoints. (they were not orig). I would like to purchase good lower balljoints with long thread stems, similar to original ones. Who sells the best replacements ?(I gave up on NOS).
I will then mount them with bolts, not rivets, since I can't find anybody, who will do a good rivet job. Any suggestions ?
