68 Tripower 435hp gets warm and hard to start. Starts great when cold. Idles at 1000 rpm. Did idle at about 700 rpm. Is something stuck? Any ideas? Thanks
Hard start
Re: Hard start
Hi Ed,
I'm not certain if the problem you are describing is related to the engine having difficulties turning over, or does it spin but not fire up?
My '69 tri-power had problems starting when hot because it would flood. Check to make sure there isn't fuel leaking from the carbs down into the intake. If they are it is likily the metering plate/body that is warped and it should be machined straight and new gaskets installed This is what fixed mine.
Howard Butler
NCRS #38700- Top
