Does anyone know how to trouble shoot prblem with lights? Instrument panel, tail, marker, headlights and parking lights won't come on. I replaced the headlight switch still no luck. There is power on terminal 1(red) of the headlight switch. If I jumper to terminal 6(light blue) the dash lights come on. Jump to terminal 3(2 brown) the tail, marker and parking lamps work. Does it sound like the new switch is bad? There is continuity between terminal 1 and 6 only(with the switch on) but dash lights still don't work using switch. Any ideas, please help. Thanks Scott
68 lighting problems
I have a very similar problem
with my '73, except that my headlights work properly. I have taken my switch apart and found it not to be the source of the problem.
I believe that the two brown wires at terminal three should be providing 12V to the switch but need to follow the wiring diagram a little further to see where they go and what they connect to.
Hope this helps.- Top
Re: 68 lighting problems
Thanks for the suggestions. I did check the fuse panel and that's where the problem was. The fuse for the "tail" lights was bad. I thought I had already checked it. After replacing it everything works fine. The only thing that seems strange is that there is still no voltage on the panel labeled "inst lps"(instrument lamps?), but the dash lights are working. Anyway, thanks again. I should have spent more time checking the obvious.- Top
It doesn't make any sense to me either. I put the original headlight switch back in and replaced the "tail" fuse and everything works. Maybe there was a loose connection or short somewhere that could show up again. The front and rear lamp harness and engine harness are new. The dash harness is the original but doesn't seem to be damaged or modified. The only problem I see is the terminals on the fuse panel look a little oxidized or rusty?- Top
