I finally got around to removing the disfunctional outer door handle (passenger side). The bottom part or the body that holds the spring broke. That was the "clink" I heard the day it failed. The solution will be to buy a new GM outside door handle. When I install the new handle, will I need to remove the rod assembly? How do I remove the rod assembly from the lock assembly?
I also have a problem with the door lock assembly in the same door. The fork that traps the door striker when the door is closed does not spring open when the door is opened from the inside. With the door opened, I completely closed the fork and then tried to open it using an curved awl as the striker and I could not get it to open. It seems to me that the assembly needs some work. I tried to clean it up with some PB Blaster while it was in the door but this did not fix it. How do I remove this assembly? Can it be done without removing the window? It's a tight fit.
