If I understand the posts in the archive correctly, a fuel gauge that sits around half full, regardless of the actual level has a ground problem. I just had my cluster slid part way out to change the ammeter, it was fine before that and I don't believe in automotive coincidences. My problem is that my temp gauge and all the gauge lights are working fine, so I think the cluster is grounded. I don't see how the fuel gauge could not be too. I plan to try a wire from the gauge to ground tonight, but even if that fixes the problem, it's still not right. The park brake warning light works, so that verifies the fuse. Thanks for some suggestions.
Fuel Gauge Grounding Again - '64
Re: Fuel Gauge Grounding Again - '64
I found the problem last night. The answer to the question is yes, they all share the same ground so if one thing works, the others should. When I reconnected the fuel gauge putting the cluster back, one of the wires pushed part way back out of the terminal enough not to make contact but not far enough to see.- Top
