69 A.I.R. Pump Drive Pulley - NCRS Discussion Boards
  • George D.
    • August 31, 2000
    • 225
    Can anyone help with the correct part number for the drive pulley that goes on the water pump for the A.I.R. for an L46 with AC?
    George
    Re: 69 A.I.R. Pump Drive Pulley
    George-----
    The original pulley was GM #3917234 and this was used with spacer (between the pump and pulley) GM #3941122 (which was 1/2" thick). Both parts are discontinued. You can use pulley 14087008, but it's a bit larger in diameter
    • George D.
      • August 31, 2000
      • 225
      Re: 69 A.I.R. Pump Drive Pulley Attn Joe L
      I'm looking for pulley that goes on the water pump not the AIR pump.
        George-----
        The drive pulley is GM #3883235. It was discontinued a long while ago, but it's available in reproduction (for about $100).
        • Craig S.
          • June 30, 1997
          • 2471
          George - now that Joe gave you the numbers, you can probably get them from Paul Baker at Goat Hill Classics. His ads are in the driveline....Craig
