For standard coil springs, the catalogs (Long Island, etc) differentiate between 63 and 64-67, with the 63 costing about 50% more. What causes the difference?
C2 front springs
Re: C2 front springs
1963 springs are unique in that they are constant rate (260 lb/in front, 162 lb/in rear). The front coils can be identified by their constant coil spacing and the rear leaf by its constant leaf arch.
Beginning in '64 Chevrolet equipped base suspension Corvettes with variable rate springs. Front variable rate coils are identified by unequal coil spacing and the rear leaf spring by variable arch on some of the leaves.
The HD spring used on Z06 and F-41 are constant rate, so the front coils are equally spaced and the seven leaf rear is constant arch, but the rates are about double the base '63 springs - 550/305 lbs/in.
Duke- Top
Steve-----
Except for the judging considerations that you mentioned, there is no functional reason that the 64-67 small block springs could not be used for a 1963. Also, keep in mind that GM did not switch to the variable rate springs because the constant rate worked, overall, just as good or better.In Appreciation of John Hinckley- Top
No. The variable rate springs along with rubber isolators for the body mounts were part of the NVH improvement that Chevrolet made for '64, and I don't think you will find any difference between the variable and fixed rate springs in normal driving, but unless your OEM '63 springs are seriously corroded or damaged I don't think you need to replace them.
Duke- Top
The frame body mounting brackets were changed in '64 to accomodate the rubber bushings. Stick with the standard solid mounting on '63. The '63s, especially coupes, have greater chassis rigidity than later models with rubber body mounts, and though the rigid mounting makes '63s a bit more harsh, it improves their handling potential and responsiveness to chassis tuning.
Duke- Top
