Ok I'm an old fart too,and I for-got why as you hold your hand cuped over the carb as the engine is runing ,the RPM picks up and the engine runs smoooother. HELP
Season Mechanic or Old Fart
Re: Season Mechanic or Old Fart
Roy,
This would indicate a too lean an idle mixture. First place I would look is a bad vaccuum leak! Knowing your tastes tend to run toward Powerglide cars like me, Don't forget to check the vaccuum modulator for a leak.
Regards, John McGraw- Top
John ! Now we do like powerglide vetts , just lazy I think. But I do have a 67 4 speed that I drive only on mornings before I get tired. It's my son-in-laws 69 vett. He put a rebuilt carb on pep-boys and it idels bad , but when I put my hand over it she runs nice.- Top
Your cupped hand is restricting air flow, making it run ricer, which is what it sounds like it wants. Therefore, without your hand, it is running too lean. Either it's adjusted too lean, or it's got a vacuum leak somewhere.- Top
One More Thing
If the carb backfires while your hand is there, you won't be happy. And it may want to backfire, seeing as how something's wrong with it, and you're fiddling with it.- Top
