I have a 1960 with a 7017320 F.I. unit. After replating the air meter throttle valve shaft I am having trouble getting it to idle down. The plating has been removed from the shaft where it rides in the housing bushing and is very free. The throttle valve to body (housing) adjustment made. Various shims tried between the shaft top and the housing (This is a common fix for this problem to counter wear on the verticle shaft. The shaft was changed to horizontal on the 63-65 units). Etc, Etc . . This is the kicker, it is totally free on or off the unit but when the car is running it sticks and you can feel a bind. This bind is not there except when the car is running.
So far I have had two friends (one is a very good mechanic and the other is a machinist) look at it and we don't have a clue. Various theories about the vacuum when running but it was never a problem before. Any suggestions would be appreciated. Don H.
