I just acquired a rear end assembly,I plan to use a as a core to go out to a rebuilder,Before I send it to him I want to make sure it is not some valuble core I should not be sending out to a rebuilder but getting into the hands of some one who needs it.
The part numbers are as follows
Driver side of case casting # 3899143
Bottom of case in between where the case cover and the spring would be is
AWW 026 E
Passenger side of case under halfshaft side yokes #A104
Passenger side of case between the mounting holes # C2
It also has threader half shafts so I am thinking it was menat for a big block car.
The half shaft yoke numbers are 3872923X
As always Your help is GREATLY appreciated
Larry Savino
AWW 026 E
Larry Savino
