1957 fuel injection
  • Robert D.
    • March 1, 1997
    • 90
    #1
    1957 fuel injection
    I have a 1957 283-250hp Corvette that fouls plugs due to the choke staying on too long and running to rich when it's on. I can start the car 6-7 times but then it's time to pull the plugs. Any suggestion's ?
  • Bill Clupper
    Re: 1957 fuel injection
    Bob, what conditions are you starting/driving the car under? The early FI units have a vacuum bypass in them, so that the enrichment diaghram runs on full rich until the electric choke has opened up. In college I ran one of these units driving from where we lived to school-1.3 miles one way. About four days of this would trash a set of plugs to the point where the engine would not clean out & run to redline without new plugs. If you're showing & thus trailering, it's even worse. Some things that can be done to "cheat" this situation (which is normal, for car's "short hopped" by the way) include the following:
    A: Hotter Spark plugs with extended tips-AC-46S or equiv.
    B: Adjust the choke to a leaner condition
    C: Adjust the rich stop on the fuelmeter to a more lean condition
    D: Make sure the choke wire is connected to the "high" side of the
    ballast resistor (not the side the Dist. connects to)
    These may help some, otherwise, notheing beats a full warmup to operating temperature, about a 10-15 mile drive at road speed. I hope this helps.
    • Bill Clupper
      • Robert D.
        • March 1, 1997
        • 90
        Bill, Thanks very much for your response.I will get right on it.
        • Robert D.
          • March 1, 1997
          • 90
