C3 Vin Plate - NCRS Discussion Boards
C3 Vin Plate
  • don justham
    C3 Vin Plate
    Simple but I have to ask. The VIN plate has come off the window pillar on my 1970 and I am going to glue it back on. Standing outside the vehicle looking in should the numbers be right side up or upside down. Thanks. Its an easy answer unless you don't know it. Thanks
  • Gregg Plapas
    Re: C3 Vin Plate
    Your numbers should read left to right, with the first number of the vin at the bottom of the pillar, and the last number of your vin, toward's the top of the pillar.
    I hope this was clear enough, and that it helps.
    gregg
      • 11608
      Re: C3 Vin Plate
      There are rivets available to reattach it correctly.
      PH
      • George Romano
        Re: C3 Vin Plate
        Where can I buy some?
          Re: C3 Vin Plate
          'Restoration' rosette rivets used to be listed in the Paragon catalog, but I haven't checked in a while....
          • don justham
            Re: C3 Vin Plate
            So, in effect the numbers are right side up from the outside of the car. Is it okay to paint the VIN plate as it is weathered? Black?
            • Richard K.
              • April 1, 1988
              • 207
              Re: C3 Vin Plate
              Regarding rosette rivets from a long ago thread on this board: Paragon no longer sells the rosette rivets, but they are available from Trim Tag Company at 847-478-8247. I've never called them, so I can't confirm this info.
