C2: Windshield washer system - NCRS Discussion Boards
  • Mark F.
    • March 1, 2002
    • 174
    As my luck dictates, the AIM for my '65 is missing the page on windshield washer hose routing. Is the center nozzle the inlet for the pump, connecting to the washer jar? Are the other two the outlets (the ones that are at about 1 o'clock and 5 o'clock as you look at the pump from the left side)?
    Thanks to some of the catalog drawings, I can determine the correct routing, but I'm not sure of origin/termination issues at the pump.
    Mark
    Re: C2: Windshield washer system
    Single nipple by itself is pump inlet, two nipples adjacent to each other are RH and LH squirter outlets. 'Correct' orientation of the nozzle assy onto the pump piston/bellows has some level of controversy.... Depending on what GM picture you study (Noland Adam's factory photos, Chevy/Fisher Body service manuals, Etc.), you'll see different orientation(s) of the nozzle assy on the pump!
    • Mark F.
      • March 1, 2002
      • 174
      Thanks, Jack. *NM*
