I have an earlier(dec 20, 62 built) 63 coupe I am restoring. Its had never had any tunnel insulation installed.(No brackets riveted into body). When did GM start installing this insulation ? Will I loose judging points, if I install insulation ? I kind of like the idea, to have this insulation for heat barrier. Also, who sells the best repro ?
Rainer
Rainer
