I adjusted my valves today (66 L36) and found the first rocker (front) on the left side fairly loose. Following the normal GM protocol - I loosened it until it clattered, then tighened until it stoped, then cranked 1/4 turn at a time until one full turn of the nut was completed. Here's the catch - the nut rides high on the stud compared to the other rocker nuts. That is to say, no threads are showing on this valve, and all the other rockers show about 1/2" of threads. On top of this, when I shut the engine down, this particuar lifter seems to bleed faster to the point where the rocker arm is noticably looser than any others. I could crank it way down before the engine would begian to bog, but I left it adjusted at one full turn past clatter.
Is this something I should be concerned about?
PS- Went through this exercise trying to chase down a persistant miss at 1500 RPM. Igintion seems fine - valves seem all okay - except for above...
