You guys have really educated me in the past few days about this 1971 TCS system and I appreciate it. I have a few questions though. On my car, the TCS solenoid is functional. A previous owner removed the wire going to the RH head temperature switch and then (I believe) screwed in the plunger on the TCS solenoid to keep it from interfering with the cars idle speed. However, when the key is turned to the ignition position, the TCS plunger extends as it should but does not retract (on warm up) as the temperature switch never signals the TCS solenoid to retract. Here are my questions: If the plunger remains extended and the vacuum to the distributor is set to a given value, does this interfer with the normal operation of the car? Would this affect gas mileage and performance? Until I get it the system straightened out, should I run the vacumm hose directly from the carb to the distributor advance? Sorry about all the questions.
Sincerely,
Rick Church
Sincerely,
Rick Church
