Power Steering Control Valve - NCRS Discussion Boards
  • Ray C.
    • June 30, 2001
    • 1132
    I am in the process of rebuilding the control valve on my 1965. I am in the process of reassembling and I am confused on the correct direction of a spring next to a ball seat. The parts view in the 63-shop manual shows the spring with the wide surface towards the ball seat. The assembly manual instructions state to install the spring with the small end down. I am assuming (bad thing to do) this means small end towards the ball seat. I would also like to know how tight the ball adjuster nut should be before backing off for the plug to sleeve key.
    Thanks for all the help!!
    Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
