C3 Tires - NCRS Discussion Boards
C3 Tires
  • John Wissocki
    C3 Tires
    I am desperately looking for a set of 4 original Goodyear Eagle GT for my 1982 CE. Any suggestions?
    Re: C3 Tires
    John-----
    I don't know where you could find a set of these. You could try eBay; just search on Goodyear Eagle GT. I don't think that you'll find what you're looking for, but it's worth a try. These tires were discontinued by Goodyear a long time ago (well over 10 years ago) and I would not expect to find a complete car set in any tire shop inventory. You might find a "straggler" here and there and if you keep after it long enough you might be able to put a car set together.
    While you're doing this, you might want to put on a set of Goodyear Eagle GT IIs. This tire is still available from Goodyear and it's available in the 255-60-15 size used on your car (it's also available in the 225-70-15 size used on other later C3s). The sidewall configuration will be somewhat different, but the tread pattern and general configuration is very close to the original Goodyear GT's.
    • Paul B.
      • April 30, 1995
      • 482
      Re: C3 Tires
      These are always in Hemming's, and are about $250 a piece NOS.
      • George C.
        • December 1, 1988
        • 583
        Re: C3 Tires
        Hi John, Give Roger Judski a call at Roger's Corvette Center in Maitland , Florida . His number is 407 628 8300 . He's a Goodyear tire freak, loves Goodyears on Corvettes. He might have some or will know where some are. Good Luck, Save the Wave .>George
