1970 AIM Available - NCRS Discussion Boards
1970 AIM Available
  • Donald O.
    • May 31, 1990
    • 1580
    1970 AIM Available
    A special thank you to Marty McDonough for the loan of his 1970 AIM and to Roberto Luis for his initial ground work on the AIM database.
    If you would like a copy, either e-mail me or let me know here - but I will need your e-addy to send it to. Same price as before and with the same 100% MONEY BACK GARANTEE if not satisfied. Same request for its use too.
    Don
  • Kevin Whiteley
    Is there a 68 or 69 AIM? *NM*
    • Reba Whittington
      Re: Is there a 68 or 69 AIM?
      There is a separate one for each year. Check p. 97 of the last issue of DRIVELINE. NCRS members get a discount.
      • Donald O.
        • May 31, 1990
        • 1580
        Its the AIM in a Microsoft Access Database *NM*
        • Kevin Whiteley
          Sorry, I was referring to
          a 68 or 69 AIM in MS Access Database. My request wasn't clear. My apologies. And thanks to those who put the Access AIM's together.
          • Donald O.
            • May 31, 1990
            • 1580
            Re: Sorry, I was referring to
            I understood, I just started on the 1964. When I finish that then I will start on the 1969.
            Currently completed are;
            1965, 1966, 1967, 1970, & 1973.
            It takes about 4 to 7 weeks for me to convert an AIM into an Access database.
            Don
            • Roberto L.
              • January 1, 1998
              • 523
              Re: 1970 AIM Available
              Thanks, glad to help. It's very time saving to have a computer based AIM. You may find a similar numbered part in different sections of the car at a finger tip, like missing screws and so on.
              Roberto, NCRS #30019, RMC
              • Donald O.
                • May 31, 1990
                • 1580
                Exactly!!
                I like to use it to check bolt head markings against other locations.
                Don
