A/C Fan Voltage - NCRS Discussion Boards
A/C Fan Voltage
  • Peter B.
    • July 31, 2000
    • 155
    A/C Fan Voltage
    My A/C fan does not really increase in power as the switch is increased. Then when I get to the max power,it turns the fan off completely.
    Any ideas?
    What is that condenser for on the input of the positive to the fan?
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: A/C Fan Voltage
    I assume this is a C3. It sounds like a bad switch.
    • Harmon C.
      • August 31, 1994
      • 3228
      Re: A/C Fan Voltage
      Their may be a in line fuse on the left hand inter fender that is used only in the high speed fan mode. I know it is their on a 73 so 72 may have an in line fuse also for the highest speed you will need to check a wireing diagram.
      Lyle
      • Jim T.
        • March 1, 1993
        • 5351
        Re: A/C Fan Voltage
        My 70 has the inline fuse for the high speed operation of the fan motor. I believe the condensor is to keep static from the radio reception.
          Correct: cap thwarts RFI to the radio *NM*
