Re: Timing Minutae
Tony, the correct/proper methods of installing/checking the distributor alignment vary somewhat by year and engine. Functionally, the limits are defined by being able to set the timing without the vacuum advance unit hitting the manifold or the shielding/brackets, AND the tach drive cable able to be attached easily and without interference with shielding, etc.
The A.I.M. usually does show what the correct angle of the distributor cap should be after installation, vis-a-vis a line normal to the engine centerline. Then, the final timing adjustment is made, per the engine spec. The '65 to '67 A.I.M.s call for different angle of distrib. cap for K66 option, and even indicates where the rotor arm should point before and after easing the unit into the engine.
I agree with Chuck Gongolff that if it wasn't for the above interference concerns, the distrib could point in any direction, as long as the plug wires were rotated to different holes in the cap, respecting the firing order, so timing could be established at #1 cylinder.
I seem to remember a GM tech service bulletin reprint (in the Restorer ?) that radically changed the distrib orientation in a 1968(?) smallblock to correct an interference problem.
I'm surprised this thread didn't delve into the subject of the proper alignment of the distributor driven gear (that meshes with the camshaft), when (re)installing on the distributor shaft --- dimple on gear in line with rotor arm, otherwise you'd be "out" half a tooth, which would shift the adjustment arc mid-point.
