Finally got the '65 small block/powerglide running. Problems now are purely electrical. Thanks to those of you who have helped me in the past few days with the minor stuff, but now the major issues have come up.
After cleaning the terminals of the turn signals, they work just fine. However, the brake and tail lamps refuse to work. My thinking is that the problem is related to the fuse block. The turn signals on my car are not (according to the fuse info in my manuals) controlled by the fuse block. The brake and tail lamps are.
My convertible seems to have sat out in the rain frequently (with the top down), as the terminals of the fuse block are rusty. I cleaned them today with a Dremel-type tool, a bore brush mounted in my drill, and navel jelly. All fuses are new and of correct amperage according to the owner's manual.
Seems to me, that since the turn signals work, the problem with the brake and tail lamps is related to the fuse block.
Any thoughts?
Thanks for your help in getting my driver on road for the first time in years.
Mark
Any thoughts?
Mark
