69 Radiator Shroud - NCRS Discussion Boards
69 Radiator Shroud
  • Michael Cole
    69 Radiator Shroud
    I have a 69 350/350 4 speed coupe. Can someone tell me the correct radiator and shroud for this car. I currently have a copper radiator with a plastic shroud. My plastic shroud is broken and I want to replace it. The AIM shows an aluminum radiator and steel shroud. I also need to replace my passenger side headlight support. Was there more than one size made for that year? Any help would be appreciated.
    Thank you
    Mike
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: 69 Radiator Shroud
    There were tow sides on the headlight.
    Not positive, but if your car has A/C you have the correct radiator and shroud.
      Mike-----
      Your car likely originally used the copper/brass radiator and plastic fan shroud that you have. For 1969, L-46 engines were delivered both with aluminum radiators and steel shrouds and with copper/brass radiators with plastic shrouds.
      The shroud that you require is GM #3956109 and it's still available from GM for about 150 bucks, list.
      The headlight supports (the cast aluminum, "u-shaped" piece) were the same for all 69s. The right side support is GM #6258534 and it's still available from GM for about 175 bucks, list.
