For a 64 coupe, I am replacing the rag joint on the steering column. Mine has a copper ground attached to the steering rag joint. It broke during the grinding off process to replace the studs with the new bolt pattern. Where can I find one? Or can one be made? I checked several catalogs and could not find one anywhere. Someone in the archives stated the copper ground was for the horn? Also, can a replacement metal clamp that holds the bolts/studs, to the rag joint and coupler be found? During the grinding off process, I damaged one a little (could possibly be used) before I figured out the easy way to do the job!!
Thanks!
Thanks!
