I have a C1 upper windshield molding with a couple pf screw holes that shouldn't be there. Is there anyone out there that repairs these kind of problems? I can weld the holes up myself, but it will look like I did it if I do! Obviously a job for a pro.
Re: C1 upper windshield molding
Ed,
be carefull with this one as I had a small holed welded up on a fender moulding and although it polished out well it was a slightly different color.
Mark.
My Vette Page- Top
Ed,
I used some 304 stainless wire in my MIG welder and after grinding and polishing, the repair had a different color to it. After flash chroming the moulding however, it is undetectable. There used to be a guy in my Austin who did this type of work, and his repairs were perfect. He used a TIG welder and applied shielding gas to both sides of of the moulding and used a different alloy of stainless. After doing a couple of these repairs, I figured that my time was better spent doing something else! If I ever get myself a TIG unit, I may try this again, but could not get the precise heat control I needed with the MIG welder, and I had real metal distortion problems. I would guess that with the thickness of your windshield header, this distortion would not be a real issue.
Regards, John McGraw- Top
