I am installing a pilot bearing on my 61. I bought a GM #10125896. I thought it would be a roller type bearing. It is a solid brass bearing with six grooves in it. Should I get a pilot bearing with needle bearings? Thanks, Joe DeLuca Member #37862
C1PILOT BEARING
Re: C1PILOT BEARING
Joe, My experience with my 56, and with numerous other vehicles, is that a new pilot bushing (probably bronze vice brass) works just as good as a pilot bearing. Make sure it slides easily onto the transmission pilot shaft before installing it into the rear of the crankshaft and put a light coat of grease on the tip of the pilot shaft prior to re-installing the transmission. Steve- Top
Re: C1PILOT BEARING
Joe----
I agree with the others; the bronze bushing will work just fine. They've served well for literally millions of miles on millions of cars. However, if you want the roller bearing it's GM #14061685.In Appreciation of John Hinckley- Top
Re: C1PILOT BEARING
As and add-on to what Steve said, after you press it into the back end of the crankshaft, make sure the transmission pilot shaft still turns free in the bearing. Sometimes if the fit is too close, the bearing will close down a bit on installation and cause a "too-tight" fit. That doesn't work well, (voice of experience!)- Top
