Power loss on 1957 Corvette - NCRS Discussion Boards
  • Dan Wichlan
    While driving at full throttle, I will suddenly lose power on my 1957, single four barrel, Corvette. If I try to restart immediately, the engine will not fire. After sitting for a minute or two, it will restart. Does anyone know what is causing this? Thanks for your help.
    Dan W.
  • James F.
    • December 1, 1985
    • 596
    Re: Power loss on 1957 Corvette
    Dan,
    With the sketchy information provided, it sounds like your problem may be fuel related. Replace the fuel filter (also their may be one inside the WCFB under the top cover big nut) and check the flow of the fuel pump. I believe there are flow spects in the '58 Chevrolet Service Manual. Regards,
    • Rob Dame
      There is also a filter on the end of the sending unit in the tank.
      My sending unit filter was quite clogged.
      Rob
      • Michael W.
        • April 1, 1997
        • 4290
        Make sure you have a vented fuel cap.
        • Robert Willis
          Are the valves set a little tight and the lifters pumping up holding the valves off of their seats ( no compression ) ?
          • john38706
            i had the same problem with a 58. pull the sending unit and replace the filter.
