C2 instrument lenses - NCRS Discussion Boards
  • Steve D.
    • February 1, 2002
    • 990
    Are all replacement instrument lenses plastic, or do tempered glass ones exist?
  • Glenn Ochs
    Re: C2 instrument lenses
    I have recently aquired the correct "glass" lenses from the local GM dealer. I haven't got the part numbers handy but I can supply them if you require.
    • Steve D.
      • February 1, 2002
      • 990
      Glenn
      Yes, please. I will need lenses for the entire instrument cluster and the clock also.
      Steve
      • Glenn Ochs
        The numbers on the boxes I have are: 6407929 small lens / 6407930 large lens. They are definatly glass. Hope this works in the USA. Worked well here(Canada). I didn't order the clock lens,I'll see if it is available tommorow. Good luck, Glenn
        • Bob R.
          • June 30, 2002
          • 1595
          Just a note. In 1963 the tach and speedo were plastic the smaller lenses were glass. The plastic does tend to discolor in time. 1964 - 1967 all lenses were glass.
          • Rick A.
            • July 31, 2002
            • 2147
            re: C2 Instrument Lenses
            check E-Bay; click on PARTS and then tyep in "1963 Corvette" in the SEARCH box and you will get about 240 entries - there is a vendor selling glass lenses for the entire instrument cluster
            Rick Aleshire
            2016 Ebony C7R Z06 "ROSA"
            • Kenneth S.
              • July 31, 1981
              • 302
              In '63 ALL the instrument lens were plastic.
              Ken
              • Joe C.
                • August 31, 1999
                • 4598
                Steve:
                Glass lenses available from Long Island Corvette Supply.
                Joe
                • Steve D.
                  • February 1, 2002
                  • 990
                  Glenn
                  Thanks for the numbers.
                  Steve
