I decided to put the MA6 dual disk clutch back in my car and apparently should have been a bit more attentive during the installation having never installed one before. The clutch does not disengage at all. When I run the motor, I cannot shift the trans. I didn't separate the one disk from the pressure plate and the other disk I installed the only way I thought it could go back in. I used the same length throwout bearing. I've adjusted the clutch to the point of removing all free play and can see that the clutch fork is indeed engaging as one would expect. Only thing that comes to mind is I put the one loose disk in backwards. This would be the disk that engages between the flywheel and pressure plate. The center of the disk projects out on one side and is level on the other. I installed the disk such that the side with the projecting center faces the pressure plate. I thought that was the only way it would install but I didn't try installing it such that the projection faced the flywheel. Anyone familiar with installation of these dual disk clucthes have any advice to offer? I don't know what else could be causing my problem. The tranny shifts fine when the engine isn't running and I haven't changed anything other than replacing the throwout bearing and switching out the aftermarket scatter shield for the original bellhousing.
Thanks in advance.
Thanks in advance.
