59 Fiberglass repair or replace? - NCRS Discussion Boards
  • John Nickelson
    I own a '59 Corvette and recently hit a deer. The front end has been badly damaged. There is a possibility that the fiberglass can be repaired. Before I get estimates I am trying to get as much information as possible. Is it better to go with a press molded replacement front end or have the fiberglass repaired? What is better for vehicle value and originality? Any input would be greatly appreciated. Thank you!
  • john38706
    Re: 59 Fiberglass repair or replace?
    john, it depends how bad the frontend is. if the whole front is damaged but you can save the lower side fenders i would put a press moulded on but use your lower side fenders. this way there will be no signs of a frontend replacement. just how bad is it?
