Can mid-year side exhaust covers be restored? If so, can I do it myself or is it best to send them out. Also, what is the cost of someone else restoring them vs myself?
Side Exhaust Restoration
Re: Side Exhaust Restoration
Don't know of any such services because, until recently, these were available off-the-shelf from GM/Chevy and the typical 'damage' that results to originals is major stone dings in cosmetic metal surfaces (especially forward behind front wheels) as well as paint wear/chip to the silver colored accent paint that runs between ribs. Labor costs to attempt 'restoration' of well worn covers basically rendered the consideration uneconomic....- Top
Jim:
I restored mine, myself, about 3 years ago, before the covers again became available in reproduction. Although they are perfect in every way, I would not repeat the process. You are better off buying new ones.
If you have a lot of time on your hands, then the trick involved, is that you must have the remnants of the clear anodizing stripped off before you can attempt to refinish them.
Joe- Top
