Dash lights - NCRS Discussion Boards
Dash lights
  • Pete M.
    • February 16, 2011
    • 21
    Dash lights
    On my 66 coupe the dash lights are very dim.System is charging and all accesories work fine.Could this be a voltage regulator or a ground issue? Thanks in advance for your input.
  • Ed Jennings
    Re: Dash lights
    You can connect a temporary ground to your dash and see if it makes a difference. Another likely suspect is the rheostat on the light switch. It could need cleaning or replacement.
