Today after a local show I went to start my 66 and the starter made an awful chattering sound and the motor turned over very slowly. After a few tries the motor caught and I was able to drive home. I tried the starter again at home and the chatter was the same with the same slow turn over of the motor. I checked all the electrical conections and they were fine. The battery is new and I don't believe it is discharged.The amp meter registered as usual when driving home. I removed the starter for the first time since owning the car and checked the numbers.The numbers on the case read 1109062 9521 4. I checked in my NCRS specifications guide and I believe the correct numbers should be 1107320. The starter looks too new to be correct to the car.( probably an off the shelf rebuilt one ) It had a paper sticker on it that read.. 12404044 323-236 A96. Can anyone identify what starter I have and maybe give me some advice as to what is wrong with the starter I have. Can you tell if it is the solinoid or the starter itself. can i get one at the local parts store as a temp replacement? Where should I look for the correct one for my car? I will be attending Carlisle this year. Thank you for any and all information.
Bruce
P.S. The motor is a 327 300 hp Correct block.
Bruce
