My 60 with a newly rebuilt motor is overheating.I bought the car as a basket case so I can offer no known history.It is a base motor with the radiator with the goose neck filler and no expansion tank. I Replaced the water pump with a rebuilt unit at time of engine rebuild. My original radiator was sent out and checked for leaks prior to start up as there was evidence of an old repair located just below the top tank. The repair looks like someone removed about 3/4" of the fins and repaired a leak. The car has a 160 degree thermostat. When I built this car my local Corvette supply/repair shop recommended I install a new radiator. They said that the original units were prone to overheating. The temp gauge and sender are working correctly. When I overheat the radiator pukes out coolant through the overflow pipe. DO you guys think that the old repair may have reduced the cooling ability of the radiator? Do you think the repro radiators afford any better cooling than the originals? Or should I look for an aftermarket unit, and are there any that are direct replacement? The car is a great driver that will never be judged.
Don
Don
