On my 66 with factory air the heater is controlled by the vacuum actuated water shut off valve. The vacuum source is from the engine manifold tee. When the heater is off (temp dash plunger is pushed in)should there be a small vacuum leak in the line that feeds the vacuum switch assy? Disconnecting the hose from the manifold tee and sucking on it I can get a vacuum but it bleeds off within a few seconds. For those with AIM manual hose #22 C60 E5
In normal driving with ac off and heater off there would be this small vacuum leak.
Doesn't sound right to me but my friend with a 67 w/air says yes there is a small bleed hole in the vacuum switch assy.
