I am assuming that I am overheating B/C the temp gauge says so and the radiator pukes coolant out of the cap overflow ( I have filled the radiator to the top). I understand that the heat and pressure will displace some coolant after the car heats up but it pukes up a lot of coolant! I recently purchased a new (used) temp sender from Maryjo for my 60. When driving, The temp gauge will rise to about 180 and hold for a while before climbing up to 220-230. I had The car idle in the driveway for 20 min or more without going over the 180 mark. Is there a quick sure way I can test the sender to be certain it is correct for the C1? I am no electronic whiz kid so I dont own meters to test resistance at the sender etc. Should I purchase a remote temp gauge with sender and take the car out for a test ride? OR does this sound like I am actually overheating to you guys.
Don
Don
Don
Don
