1966 Odometer Reset Button Location - NCRS Discussion Boards
  • ronnie Robertson # 36786
    I have a 1966 Corvette Coupe with air conditioning. The odometer reset button is on the emergency brake bracket. When I removed the e-brake bracket for repainting, the hole where the odometer reset button is located looks relatively crude. Is this the correct location for the odometer reset button?
  • Robert W.
    • March 1, 1977
    • 81
    Re: 1966 Odometer Reset Button Location
    My 66 air car has a bracket between the headlight switcha and left air vent that my odometer cable fits through. I have hazard warning (V74) that is installed on the braking brake lever support. I believe it may be the right hand vent bracket since the right hand vent is controlled from the center section on air cars.
      Robert,
      My car does not have a hazard warning flasher option.
      Ronnie
      • Randy S.
        • January 1, 2003
        • 586
        Ronnie,
        According to owners manual pg 13 the rest button is either under the telescoping steering column or just to the right of it for standard columns.
