Three questions re 66 L72 427/425 original motor :
1)re oil pressure fitting by the oil filter that reduces from the larger block orifice thread size to accept the smaller oil pressure line fitting - Curious if the original fitting was brass or steel and if it was installed by Tonowanda plant (ie painted) or St Louis (unpainted?)
2)were the original oil galley plugs hex or square head design ?
3) I could not find above detail in the AIM - is there an available factory assembly manual (AIM) for the 427 L72 from Tonowanda plant or similar quide ?
Thanks in advance for you input
