Turbo-400 Trans Question
  • Pat Bush
    Hi all -
    Quick question. My 71 auto convertible has a tendancy to not smoothly engae into reverse even at a curb idle of 600. It kind of bangs and engages fine but it does this mostly when the car is cold even after I kick the throttle down to curb idle. I have no issues in drive. Is this an adjustment, ujoint, or the tranny mount/differential carrier mount or something in the tranny?
    Thanks is advance -
    Pat
    • June 1, 1974
    • 8288
    Re: Turbo-400 Trans Question
    I'D INVESTIGATE U-JOINT WEAR BEFORE CONDEMNING THE TURB-400. MIKE
    • Eric Fairclough
      It sounds like the transmission mount is craked all the way through. I have had this happen before.
      • Jack H.
        • April 1, 1990
        • 9893
        One idiosyncrasy of the '71 CEC system is for the carb's CEC solenoid to fire (obtain elevated curb idle + dist vac advance) in reverse as well as in forward high gear(s). This is ONLY true of A/T cars and not for stick shift....
        As a byproduct, that CEC system 'funny' stress tests your drive train U-joints along with the rear end's 'snubber' bumper.
        • Pat Bush
          I notice when you put the car in reverse, the butt-end lifts up. Any ideas?
          • John Walker
            Pat; that is funtion of the torque leverage on the suspension. The opposite happens when you put it in drive, the rear end goes down.
