To follow up on the C2 overheating thread, just how is the fan clutch supposed to operate?
For example, when the motor is cool (as in fresh start), it should free-wheel freely, right? By hand, you should be able to turn it.
Then, when motor up-to-temp (as in driven for an hour or so), it should turn by hand much more difficultly (or not at all), right?
I thought this might be two easy experiments to run, since I am observing what seems to be pretty close to what the gentleman recently described - 200+ at idle; 180 steady on the road.
FYI, my fan shroud hasn't been tampered with in any way, and I'm running a brand new DeWitt's AL in my '67 L-79. Coolant level and timing all OK.
Thanks for your comments.
Tom
Tom
