Teo bulbs go under the shifter plate. One inserts vertically up into the unit that holds the two temperature wheels and it looks like the other inserts horizontally into the same unit but closer to the firewall side. The question is this, the vertical bulb comes on when you tun the headlights on and the other one comes on and stays on after the headlights are turned off. It actually stays on all the time. This isn't right is it? This bulb inserts into a little housing and lights up when this housing contact another metal piece. Is it a bad ground or should it stay lit all the time?
C3 Interior lighting
