In the area where the casting date is on an 010 right rear flange all I found was conv1 and a large T 6. Where is the casting date on a 014? This is a very early 77 with an orange block and the stamp pad appears correct with the body build date but I need the cast date for the year. Is the T-6 a date? Lyle
1977 Corvette 3970014 block
Re: 1977 Corvette 3970014 block *TL*
Lyle,
0014 cylinder cases have the casting date on the driver's side right above the 3970014, on the rounded part for the upper two of the vertical bell housing bolts. The date will read horizontally, in the usual format - alpha character, one or two numbers for the day of the month, and two numbers for the year. You will find the year portion of the date has two digits = 77, as was the Tonawanda practice.
The T in the T6 is for Tonawanda, where the 0014 cases were cast. We see a lot of these in 1972 MY Corvettes.
Terry- Top
