Hello all --
I have a bit of a quandry here.... I have a 1970 coupe and a 1971 convertible I just purchased. the ammeter does not work on the 71 but does on the 70. After reading through the service manual and tracing a bunch of wires I ended up at the horn relay. Unfortunately, I see the the wires, but the diagram does not show where to hook them up....
The wiring is reversed on the 71 as opposed to what is on the 70. The 70 was just professionally restored so I am assuming this is correct, but I wanted to verify and see if there were any changes in 71.
The 71 is wired:
BAT Terminal - Fusible Link, Large booted 10ga? Red wire (goes into harness)
Other Terminal - Two Red wires 12GA and OR/BL wire
The 70 is wired:
BAT Terminal - OR/BL wire
Other Terminal - Fusible Link, and two red 12Ga wires
Now, the horn works fine on both as does the iginition buzzer. I seem to have an extra BIG red booted wire on the 71 that is not on the 70. The ammeter works on the 70. The harness on the 71 is original. The harness on the 70 is a lectric limited. Both cars have AC. The 71 also has power windows.
Which one is correct?
Sounds like a test question doesn't it :-) Any help here would be appreciated. Both cars run great but I am thinking something is rotten in Denmark.....
Thanks in advance -
Pat
The 71 is wired:
The 70 is wired:
Thanks in advance -
Pat
