Error 500: Internal Server Error - John?
  • John Hinckley (29964)
    Just signed on, and four of the first ten posts I clicked on generated a screen with the following (instead of the post):
    Your request could not be processed due to an internal server error. The server was probably busy handling other requests. Use your back button and retry your request. If you were making an order rest assured that you will not be double billed if there was a server error.
    Copyright © 1997 -- 2002. All Rights Reserved.
    Administrator
  • Craig Schultz (29385)
    • July 1, 1997
    • 2471
    Re: Error 500: Internal Server Error - John?
    John - I am getting the same errore on the 63 turn signal post...but no others so far...Craig
    • Lyle Chamberlain (24961)
      • September 1, 1994
      • 3228
      John No worry if you are billed double 0x0=0. This site has not had a glitch in a long time but it has one now. Lyle
      Lyle
      • John Waggoner (107)
        Administrator
        • November 1, 1974
        • 4846
        Re: Error 500: Internal Server Error - John? *TL*
        The server was real busy about that time. There is a threat of Web Site Hijacking this weekend. I was just doing a precautionary backup. When was the last time you backed up your system?
        Administrator
        www.ncrs.org
        • William Clupper (618)
          • June 1, 1975
          • 6037
          Problem still exists @ 7:30 ???
          Bill Clupper #618
            • July 1, 1997
            • 2471
            Bill - it seems to be only on the posts that were placed in the earlier time frame today, and they remain as permanent errors on the postings. Current posts seem to work....Craig
            • Robert Wilson (1334)
              • March 1, 1977
              • 81
              John - There appears to be a string prior to your post that gives this message starting with Bramlett's post for me. After your post anything posted is readable.
              • Len Rayca
                John: I just tried the thread "63 turn signal " @ 7:38 PM eastern daylight time and received the error message.
                  • July 1, 1997
                  • 2471
                  I think the problem remains and relates to the posting itself, not related to accessing it later...Craig
