72 half shaft u-joint grease fittings. - NCRS Discussion Boards
  • ERIC FAIRCLOUGH
    Hello, Why do the half shafts u-joints only have grease fittings on the outside u-joint (nearest to the wheel) and the inside (nearest to the differential) do not? 72 454/400
  • Mike M.
    • May 31, 1974
    • 8365
    Re: 72 half shaft u-joint grease fittings.
    original midyears u-joints didn't have any zerk fittings and i suspect the c-3s also lacked grease fitings. mike
    • Craig S.
      • June 30, 1997
      • 2471
      Original GM U-joints did not use any zerk fittings. Generally, the drilled U-joints are weaker and can break, usually with high torque big blocks and hard driving...Craig
      • Harmon C.
        • August 31, 1994
        • 3228
        Eric If the grease fittings are installed on the half shafts you may not be able to grease them as I have found it very hard to do without removing the shaft. No room to get at the grease fitting and as I remember the inside is hardest to get at..Your inside joints may be original. Lyle
        Lyle
