Engine Identification - NCRS Discussion Boards
  • Ron Cwiklinski
    I need some help in identifying the engine I pulled out of my 62.
    Casting number 3959512, cast date K 27 0. Pad was stamped A 1957 9T V0112XCB.
    One head is 3927186 (LT1 head?) and the other's cast number is 3991492.
    Just trying to determine if its worth saving or freeing up my engine stand.
    Thanks in advance.
  • Jerry Clark
    Re: Engine Identification
    Ron;
    This from Mortec;
    3959512....327...62-67...2...Was also used for some "CE" replacement blocks
    3927186 3927186....69-70...302/350......Camel hump,64cc chambers,accessory holes
    3991492....70-up................over the counter,Camel hump,64cc, straight or angle plug
    39914923991492....70-up................over the counter,Camel hump,64cc, straight or angle plug
    I'll leave the stamp to those that can read the books
    Best of Luck
    jer
    • Kevin Whiteley
      I couldn't find 3959512 in my limited library, but assuming (I know) that the 62-67 use is correct, the cast date of November 27, 1960 or 1970 (K 27 0) doesn't make sense. I also don't show any reference to XCB. There is a CXB, which is for a BB, and a CKB for 350's in various vehicles (non-Corvette) in 72-74.
      The V0112 indicates a Flint engine assembled on January 12. That's the limit of my info.
