After replacing the clutch in my coupe, I reassebled the N11 system only to find an exhaust leak in the left pipe joint. Looks like the pipe is well at the joint, but it might be able to go in a bit farther.
Is there a tool that pulls the sections together rather than whacking, twisting and wrenching on the pipes? And, the AIM calls for some type of sealer on the joint. What is this compound and is it recommended to use? Thanks.
