Hopefully some of you remember my earlier posts concerning the problems I've been having with my dual disk (MA6) clutch. To review, I have a '69 427 that's been fitted with a dual disk clutch. However, the setup appears to be for a 454 since the clutch is for a fine spline trans (which the car now has) and the flywheel has the extra casting material used for an externally balanced engine. BUT the flywheel also has been drilled extensively to remove material. Finally, my questions:
- Is drilling the flywheel in this manner typically done by a machine shop to balance an engine? If so, does this prevent me from being able to replace the flywheel with a standard 427 flywheel since it would throw off the balance?
- Is it possible this was done to neutralize the flywheel (as far as balancing goes) since it's a 427 which is not externally balanced?
- Can a machine shop check the balance of a flywheel as a stand alone piece to tell if it's neutrally balanced?
Thanks for the help.
