My water temp gauge decided to go south just a few days from heading to Hershey.
When I turned on the ignition (engine cold), the needle s**** way past 250 to about the 4:00 position and stayed there.
Gauge and sending unit were synched not too long ago by a well known shop (can't reach).
Here is what I know:
Tested the sending unit at about 80 degrees - reads 600 ohms
Have continuity in the wire back at the terminal at the clip, same reading.
When connecting the two terminals at the clip, still reads 600 ohms
When ignition is turned on - no resistance. Shows 12.6V
Start motor and warm up, still no resistance, shows 13.6V
When ignition is off, then you can watch the resistance go down (250 and below)
While ignition is off, needle will move slightly to about 3:00, but goes back to about 4:00 when key is on.
Won't pass ops in this condition, any suggestions?
Bill Becker
Bill Becker
