Getting ready after many years to install radiator into my 68 Coupe small block with A/C.
I believe there are some seals that go between the A/C condenser and the radiator.
Where is the best place to find the exact positioning of these seals.
Also, should the seals be installed to the radiator before the radiator gets installed in vehicle or should the seals be installed to the car and then the radiator installed ?
Lastly, should the shrouds go in first and the radiator last. I seem to recall there are clearance issues. Fan and pulleys have not been installed to engine yet but water pump has been installed.
It's been years since I disassembled the car and memory is not as good as it was once. (I should have taken better notes at disassembly)
Thank you for an y and all help,
Kurt Bunting # 26406
